Russell79
#1 Posted : Monday, June 7, 2010 3:09:23 PM(UTC)
Russell79
Replaced the bake element as is it was burned off a piece. Replaced that today and now when I go to heat it up I get nothing. I can hear a relay click like before when it work as it was warming but it's not. I took all panels off and inspected wires and nothing broken or burned. Is the control display the culprit?
#2 Posted : Wednesday, June 9, 2010 4:40:29 AM(UTC)
Replacement parts for AMANA AER5735QAW Range - S/c F/s Ele | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16025648.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/16025644.pdf
I am assuming that the stove top elements work OK so you know that it is getting 240 volts.
Try Broil if that also does not work the hi-limit switch may be open.
Your unit may not have one, see below
http://www.servicematters.com/maytag_library/docs/TDC-0065-B.pdf
Russell79
#3 Posted : Wednesday, June 9, 2010 5:20:24 AM(UTC)
Russell79
Yes the stove top does work. Broil does not. So if my range does not have the "hi-limit" switch does that mean it's the control panel? Once again thanks for your help.
#4 Posted : Wednesday, June 9, 2010 5:24:49 AM(UTC)
I would say yes if all the wiring looks OK.
Odds are that it is the hi-limit as this is a common problem.
