Replaced the bake element as is it was burned off a piece. Replaced that today and now when I go to heat it up I get nothing. I can hear a relay click like before when it work as it was warming but it's not. I took all panels off and inspected wires and nothing broken or burned. Is the control display the culprit?
THIS FORUM IS DEAD!!!!!!! |
Yes the stove top does work. Broil does not. So if my range does not have the "hi-limit" switch does that mean it's the control panel? Once again thanks for your help.
I would say yes if all the wiring looks OK. Odds are that it is the hi-limit as this is a common problem. |
