Lower oven door locked shut following clean cycle, while disassembling and re-opening door, broke the 3-terminal Microswitch (part # AP2023955):eek: ; do not know which colored wires go to which terminals:confused:
New part due to arrive in 2-3 days. Also, does this switch effect oven temperature? :( Thanks for any assistance you all can provide!!!:rolleyes: Cheers! Jim
Hi Jim, Look for the wiring diagram. It could be inside the control panel or behind the bottom drawer. The switch has to be high temperature resistant. Gene. P.S. The switch description (part# AP2023955) says this is 2 terminals switch. The model number you posted is incomplete.
