aknittle
#1 Posted : Tuesday, July 15, 2008 5:33:32 PM(UTC)
aknittle
Lower oven door locked shut following clean cycle, while disassembling and re-opening door, broke the 3-terminal Microswitch (part # AP2023955):eek: ; do not know which colored wires go to which terminals:confused:
New part due to arrive in 2-3 days.
Also, does this switch effect oven temperature? :(
Thanks for any assistance you all can provide!!!:rolleyes:
Cheers!
Jim
#2 Posted : Wednesday, July 16, 2008 3:43:51 PM(UTC)
Hi Jim,
Look for the wiring diagram. It could be inside the control panel or behind the bottom drawer.
The switch has to be high temperature resistant.
P.S. The switch description (part# AP2023955) says this is 2 terminals switch. The model number you posted is incomplete.
