raminla
#1 Posted : Wednesday, June 2, 2010 12:14:35 PM(UTC)
raminla
I have a Magic Chef built in oven with electric glow ignitor, I Had to correct a small leak, it worked (lighted up) fine before, I used soapy water to find a leak at the fitting before the regulator where the flex line and shut off valve is located. Model 9112VUV afterward , the Oven wont turn on, the glow ignitor works but the gas is not igniting, I took it all apart again to clear any obstruction if any and still wont light up. As I mentioned before, the gas pressure regulator ,ignitor all worked now it doesnt, all I did was secured a breach at the connector, can anyone explain the Cause?:confused:
#2 Posted : Wednesday, June 2, 2010 6:42:39 PM(UTC)
Make sure the gas shut off valve for the range is open and the oven shut off valve on the pressure regulator (red piece) is open as well.
raminla
#3 Posted : Wednesday, June 2, 2010 7:37:23 PM(UTC)
raminla
I did make sure these valves are open however still not firing up.I feel the ignitor is working fine however I am not sure how to test it
#4 Posted : Wednesday, June 2, 2010 7:43:23 PM(UTC)
Very likely the igniter does not draw enough current to open the gas valve. You have to measure it and if it's 3.2 amps or less, replace the igniter.
- The oven igniter Part number: AP4012072
raminla
#5 Posted : Wednesday, June 2, 2010 8:06:53 PM(UTC)
raminla
Thank you, I will do as you said.
#6 Posted : Wednesday, June 2, 2010 8:09:24 PM(UTC)
