shorthorn
#1 Posted : Friday, May 28, 2010 7:15:54 PM(UTC)
shorthorn
my ge washer has started overfilling and when tub gers full runs out, could it be the water/valve/ solenoid not opening and closing. thanks
#2 Posted : Saturday, May 29, 2010 3:39:41 AM(UTC)
Replacement parts for General Electric WHSR2070V3WB Washer | AppliancePartsPros.com
Most likely cause is the water level switch (Item 10 in Section 1).
his switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
Note: I am assuming that you can stop the water flow by unplugging or turning off the unit.
If the only way to stop it is to shut off the taps your water valve is shot.
GE washer overfills (Washer Repair)
by Shad Blewett 11/9/2013 6:07:54 PM(UTC)
GE Washer overfills (Washer Repair)
by sprankles2012 10/5/2012 5:03:01 PM(UTC)
GE Washer Overfills and does not start Washing (Washer Repair)
by mopar73 11/3/2009 5:09:50 PM(UTC)
