jwilliams
#1 Posted : Wednesday, July 9, 2008 7:22:28 AM(UTC)
jwilliams
With the load size on large or super, the tub overflows. When on medium it doesn't. Does not always go through a spin cycle no matter what the setting.
abadfish66
#2 Posted : Wednesday, July 9, 2008 11:35:38 AM(UTC)
abadfish66
what you need to do is remove the front panel of the washer, there are 2 clips about 3-4 inches inward from the edge. get a putty knife and push in between the top and front panel to release the clips. Now on the left side of the tub, there is a small clear rubber hose, the end of this hose is most likely clogged. pull it off the tub and cut the end about 1 1/2 inches is good, now get something small to clean the nipple on the tub. Put the hose back on and run a load, post results....make sure the whole time you are doing this that the tub is empty of water.
jwilliams
#3 Posted : Friday, July 11, 2008 12:06:32 PM(UTC)
jwilliams
Thanks for your help. It was an easy job that I thought would be hard. I never new I could take the front off so easily.
Thanks again Jim
