Barry Lee
#1 Posted : Sunday, May 23, 2010 6:13:27 PM(UTC)
Barry Lee
Took a Quick look at dryer and all works.
The All = Knobs,timer,wiring,motor,vents and is clean.
It takes 3-4 times to dry 1 load?
Yes the heating elelemint gets hot. Is there a thermostat switch to keep it on longer?:)
FL-Man
#2 Posted : Tuesday, May 25, 2010 5:16:18 PM(UTC)
FL-Man
Check the fan. I had the same symptoms and the squirel cage fan had lint built up on it to the point that although it would spin, it hardly blew at all. After I cleaned it with a screwdriver, performance dramatically improved.
#3 Posted : Wednesday, May 26, 2010 4:43:49 AM(UTC)
Replacement parts for WHIRLPOOL LEB6200PQ0 29" Electric Dryer | AppliancePartsPros.com
Here is your wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
[COLOR="Blue"]Is there a thermostat switch to keep it on longer?[/COLOR]
The operating (cycling) thermostat (Item 8 in Section 3) controls the temperature.
Note: It has a built in heater which when turned on lowers the units temperature, causes it to cycle more often.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
