Took a Quick look at dryer and all works. The All = Knobs,timer,wiring,motor,vents and is clean. It takes 3-4 times to dry 1 load? Yes the heating elelemint gets hot. Is there a thermostat switch to keep it on longer?:)
Check the fan. I had the same symptoms and the squirel cage fan had lint built up on it to the point that although it would spin, it hardly blew at all. After I cleaned it with a screwdriver, performance dramatically improved.
Here are your parts Replacement parts for WHIRLPOOL LEB6200PQ0 29" Electric Dryer | AppliancePartsPros.comHere is your wiring diagram http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdfTook a Quick look at dryer and all works. The All = Knobs,timer,wiring,motor,vents and is clean. It takes 3-4 times to dry 1 load? Yes the heating elelemint gets hot. [COLOR="Blue"]Is there a thermostat switch to keep it on longer?[/COLOR] The operating (cycling) thermostat (Item 8 in Section 3) controls the temperature. Note: It has a built in heater which when turned on lowers the units temperature, causes it to cycle more often. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems |
THIS FORUM IS DEAD!!!!!!! |
