2 Pages12>
Tunaman
#1 Posted : Monday, July 7, 2008 3:02:39 PM(UTC)
Tunaman
Everything else appears to work, the clock, timer, light, display. It simply will not heat anything up.
I need help.
:confused:
#2 Posted : Tuesday, July 8, 2008 1:20:58 PM(UTC)
Does it make any unusual noise?
Tunaman
#3 Posted : Tuesday, July 8, 2008 1:27:43 PM(UTC)
Tunaman
No strange noises at all. Like normal, once the time is set and you press the start button, the carousel works, the light is on and the timer is working.
In the past and on another m-oven, I replaced a large fuse and I was good to go. However, with this oven, I see no access to such possibility.
08 Jul 08
#4 Posted : Tuesday, July 8, 2008 1:34:33 PM(UTC)
Most likely the problem is a bad magnetron. In order to replace it the microwave has to be removed from the cabinet.
- The part number for the magnetron is AP4315294
Tunaman
#5 Posted : Tuesday, July 8, 2008 1:48:39 PM(UTC)
Tunaman
Is this a hard fix? Is it a relatively simple repair?
I am assuming I will have to remove the m-oven from the kitchen cabinets.
#6 Posted : Tuesday, July 8, 2008 4:05:36 PM(UTC)
Yes, the microwave has to be removed and taken apart.
Tunaman
#7 Posted : Wednesday, July 9, 2008 7:44:53 AM(UTC)
Tunaman
Thank you. I took a quick look at the installation. It appears as though it mounts by some means from the top. I'll keep you posted. By the way, is the magnatron high dollar to the extent that maybe I should consider buying a whole new oven? This one was here when we moved in.
I appreciate your input and suggestions. Thanks again.
:confused:
#8 Posted : Wednesday, July 9, 2008 12:16:37 PM(UTC)
Your decision to fix or replace the microwave should be based on the condition and age of the existing and cost of repair vs price for a new.
Tunaman
#9 Posted : Tuesday, July 22, 2008 9:07:38 AM(UTC)
Tunaman
I removed the exterior cover of the oven and could see nothing visibly wrong. With the cover off, I carefully and briefly powered up the unit and again, everything appears to work fine. I am assuming that the magnatron is the one component located just above the transformer with a cooling fan blowing on it. I also noted a large capacitor in the vacinity. Once the AC power is disconnected, i.e. the power cord, are there any precautions I should be aware of during dissassembly?
#10 Posted : Tuesday, July 22, 2008 10:14:29 PM(UTC)
The first and very important thing is to discharge the capacitor.
cvex4370B Jenn Air Grill element does not heat up (Oven Repair (including Ranges and Cooktops))
Belarus Guest 4/13/2021 8:44:32 AM(UTC)
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 11/10/2016 10:53:37 AM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Dryer runs but does not heat (Dryer Repair)
by blm1964 2/13/2015 8:54:47 PM(UTC)
Lower oven element does not heat (Oven Repair (including Ranges and Cooktops))
by throopwh 1/21/2015 6:26:46 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
Oven will overheat/broil burner goes bright red/bake burner does not heat (Oven Repair (including Ranges and Cooktops))
by Mitch29 11/14/2013 10:45:29 AM(UTC)
Microwave does not heat (Microwave Repair)
by flynkites 2/4/2013 6:28:06 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
dryer runs but does not heat (Dryer Repair)
by rdrobertson15@yahoo.com 12/2/2012 7:10:03 AM(UTC)
2 Pages12>
