aceg200
#1 Posted : Friday, May 21, 2010 5:30:44 AM(UTC)
aceg200
Sounds like a coin is causing noise when the dryer spins. However I cannot see any problem when inspecting inside. How do you raise the top of the dryer so you can see inside, or otherwise inspect for foreign object causing this noise?
thanks
sidfink43
#2 Posted : Monday, May 24, 2010 12:25:29 PM(UTC)
sidfink43
I think this tech sheet will show you how to get into it, see page 11 etc.
http://www.servicematters.com/d...heet%20-%20W10054150.pdf
aceg200
#3 Posted : Wednesday, May 26, 2010 11:49:30 AM(UTC)
aceg200
Thanks :D for your help!
How to raise dryer top? (Dryer Repair)
by wewelch 2/12/2010 12:55:50 PM(UTC)
