terimanx
#1 Posted : Sunday, July 6, 2008 7:55:35 AM(UTC)
terimanx
My husband went ahead and tore down the noisy washer. We are at the point of a bad bearing in the bottom of the tub. How do you remove this bearing, as the tub is plastic and could poss. damage easily.
#2 Posted : Monday, July 7, 2008 6:50:20 AM(UTC)
This is a big job! Go to web site www.appliancejunk.com and download the 16022937 Maytag Amana service manual.
You will need the special spanner wrench and maybe a gear puller. I use pieces of metal or washers to spread the tub springs, no need for the special spring spreader.
I have turned down this job before, too hard and risky.
terimanx
#3 Posted : Monday, July 7, 2008 8:34:46 AM(UTC)
terimanx
Thanks, looked all over for a manual. We didn't get to the point where we needed the springs removed. The bad bearing was in the outer tub.
