rvorama
#1 Posted : 15 years ago
rvorama
Replaced the gasket on the side by side refigerator door with no problems.
Now when I close the door it does not seal tightly. I need to give the door a slight push and then it seals correctly. I have applied vaseline, etc to rubber seal and I still have this problem. If I forget to give the door a push when closing, the door will stay slightly open. When I push the door closed it seals fine.
Any suggetions would be greatly appreciated.
RV
#2 Posted : 15 years ago
Here is the parts breakdown
Replacement parts for AMANA SRD26VE Ref - SXS/I&W | AppliancePartsPros.com
Check the door closure cams on the bottom hinge, Item 32 in Section 11
door will not close tight (Oven Repair (including Ranges and Cooktops))
by btk4962 13 years ago
