rvorama
#1 Posted : Wednesday, May 19, 2010 10:14:44 AM(UTC)
rvorama
Replaced the gasket on the side by side refigerator door with no problems.
Now when I close the door it does not seal tightly. I need to give the door a slight push and then it seals correctly. I have applied vaseline, etc to rubber seal and I still have this problem. If I forget to give the door a push when closing, the door will stay slightly open. When I push the door closed it seals fine.
Any suggetions would be greatly appreciated.
RV
#2 Posted : Thursday, May 20, 2010 3:47:07 AM(UTC)
Here is the parts breakdown
Replacement parts for AMANA SRD26VE Ref - SXS/I&W | AppliancePartsPros.com
Check the door closure cams on the bottom hinge, Item 32 in Section 11
door will not close tight (Oven Repair (including Ranges and Cooktops))
by btk4962 4/28/2012 2:33:54 PM(UTC)
