I replaced the icemaker. Piece of cake. It did not start working. I did the H - T Short to make it go through the cycle. It never allowed water in. I manually placed water in the maker and it made those cubes. It seems we are right back where we started. Help!!
Bump to get this looked at again. Still need help. Thanks!
Bump - Still need help!!!!
Unplug the ice maker and check the resistance at the socket plug between the white and tan wires terminals.
Post the results.
To the IM - Open To the Water Valve - 0.35 Ohms Verified the wiring harness good.
Thanks in advance.
Bump. Still need resolution.
Please! I still need help on this situation.
Still need help. Please post a reply. THanks!
Originally Posted by: Trey723  ...To the Water Valve - 0.35 Ohms... It shows there is something wrong with the water valve solenoid or somewhere on the way between the plug and the solenoid. Gene.
