I had an issue with my dishwasher losing power and stopped working. we replaced a broken door handle, it ran two cycles and stopped working. i will push buttons on it each day and normally there is no power lighting any buttons up. periodically it will get power and i can run one cycle. usually once every 2 wks. what would cause it to have intermittent power to it? when it runs, it works fine. it's just after it runs a cycle that's it till who knows when....
THIS FORUM IS DEAD!!!!!!! |
Denman thank you so much! i have been looking online for some sort of service manual with no luck. i will give this a shot! thanks again!
