stacym321
#1 Posted : Monday, May 17, 2010 5:44:54 PM(UTC)
stacym321
I had an issue with my dishwasher losing power and stopped working. we replaced a broken door handle, it ran two cycles and stopped working. i will push buttons on it each day and normally there is no power lighting any buttons up. periodically it will get power and i can run one cycle. usually once every 2 wks. what would cause it to have intermittent power to it? when it runs, it works fine. it's just after it runs a cycle that's it till who knows when....
#2 Posted : Tuesday, May 18, 2010 3:20:36 AM(UTC)
Replacement parts for MAYTAG MDB9750AWW Dishwasher - Undercounter | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16022783.pdf
And a tech sheet
http://www.servicematters.com/maytag_library/docs/16026391.pdf
Since it ran a couple times after you replaced the latch I would start there.
Could be one of the interlock switches is not closing reliably.
Also check the wires going from the control panel to under the unit.
Some time ago I had a run of units where the wire nuts connecting the unit to power had bad connections so I would also check there.
Be sure to remove power to the unit when working on it.
stacym321
#3 Posted : Tuesday, May 18, 2010 8:29:43 AM(UTC)
stacym321
Denman
thank you so much! i have been looking online for some sort of service manual with no luck.
i will give this a shot!
thanks again!
