gschone
#1 Posted : Thursday, July 3, 2008 8:47:46 AM(UTC)
gschone
The machine won't drain, I checked the drain hose for blockage, checked the drain port for blockage and found nothing. I have the drain pump off and found water inside the armature casing behind the propeller.
HOW DO I CHECK TO SEE IF THE PUMP IS BAD???
WOULD THE WATER CAUSE IT TO NOT DRAIN???
When I ran it before disassembly water was flowing through the drain hose during the rinse/wash cycle.
Any ideas of what is wrong or how to diagnose it would be greatly appreciated.
Greg
#2 Posted : Saturday, July 5, 2008 6:32:22 PM(UTC)
Greg,
Did you check the air gap on top of the sink (if there is one)?
Put the drain pump back, put the other end of the drain hose in a bucket and check how it'll drain.
Vintage Kenmore won't drain, spins slow if at all (Washer Repair)
by OlexFo 7/3/2016 7:26:42 PM(UTC)
Kenmore won't drain/advance to next cycle (Washer Repair)
by Mike Anderson 5/30/2012 1:41:25 PM(UTC)
Kenmore won't drain or spin (Washer Repair)
by Simdawg 11/27/2011 2:16:59 PM(UTC)
Kenmore won't drain water. (Washer Repair)
by brcaldwe 10/22/2010 8:11:39 AM(UTC)
Kenmore won't drain, pump ok! (Washer Repair)
by Susangopher 1/17/2008 1:19:03 PM(UTC)
