Gene got 3 new washers in today all 3 have the same problem they will not let in water in any mode. Didn't get a chance to check them out thougth you may have hear of some new timer or or switch problems.
Thanks Earl
Checked them this morning, ALL had defective water temperature switches. Tried 4 different parts sources (including Whirlpool) all were out of stock. Whirlpool site showed NLA on one screen and on order on another. Sounds like a high failure item. Why would a manufacturer install a high failure rate item on a new product????????
Hi Earl, According to the Whirlpool service pointer issued on June 1 of this year the cause of the problem could the out of calibration software in the ATC. Gene.
