Horse
#1 Posted : Monday, May 10, 2010 12:16:59 PM(UTC)
Horse
machine not making ice
try to add freon thru the high side
gauges reads 48 PSI
I only got the left side or the blue side conected
the compressor got one service valve by it self
the compressor it's real cold
and water to but it's not making ice
any sugestiones. should I add freon thru the service line
Thanks.
FridgeDoctor
#2 Posted : Monday, May 10, 2010 3:03:38 PM(UTC)
FridgeDoctor
Groups: Expert
gauges reads 48 PSI
Thanks.
unless you are well versed in working on a hermetically sealed refrigeration system, and if you are asking on here you are not, you as a consumer should never even consider doing anything to the hermetically sealed refrigeration system. I can only hope that you have not compromised the system, and have not allowed any ambient air, including the moisture it contains, into the system, and thereby making the entire unit useless. Adding refrigerant to a refrigeration appliance is VASTLY different than adding freon to the car A/C unit, which can and does lose refrigerant.
If the compressor is really cold, chances are the compressor is not running, that, and not low refrigerant level, is your problem. could be the compressor or the start kit. But if you have opened up the system, it wont matter.
But I fear that you may have just bought yourself a new refrigerator sir.
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
Kenmore ice machine 106.89583703 (Refrigerator & Freezer Repair)
by UncleBoris 10/18/2022 3:59:55 AM(UTC)
Kitchen aid under counter ice machine (Refrigerator & Freezer Repair)
by Guest 4/8/2022 12:20:43 AM(UTC)
ice machine stopped making ice model MFI2665XEM7 (Refrigerator & Freezer Repair)
by Guest 8/29/2021 2:12:43 PM(UTC)
Subzero undercounter ice machine problem (Refrigerator & Freezer Repair)
by gormally 8/5/2021 6:05:14 PM(UTC)
GE/Whirlpool Ice Machine ZDIS15CSSN (Refrigerator & Freezer Repair)
by djs5672 6/29/2020 5:29:07 PM(UTC)
GE Refrigerator Mod#GSS20IEPHWW ICE Machine Noise (Refrigerator & Freezer Repair)
by Raiderintn 4/22/2020 7:43:00 AM(UTC)
Ice machine cleaning mode (Refrigerator & Freezer Repair)
by MrMedic 3/19/2020 8:06:00 AM(UTC)
Kitchenaid ice machine not getting water consistently (Refrigerator & Freezer Repair)
by neonot 1/2/2020 9:14:38 AM(UTC)
Kitchen Aid Stand Alone Ice Machine Recirculation Pump Question (Refrigerator & Freezer Repair)
by hokiehivpi 10/25/2017 6:49:53 AM(UTC)
Ice Machine (Refrigerator & Freezer Repair)
by JDHomeRepair 6/27/2016 10:33:44 AM(UTC)
by patrick alva 9/16/2015 5:03:00 PM(UTC)
Kitchenaid Superba ice machine cleaning light blinking (Refrigerator & Freezer Repair)
by deadbone8 11/3/2014 9:10:05 AM(UTC)
Whirlpool Gold Undercounter Ice Machine (Refrigerator & Freezer Repair)
by IdealMammal 6/23/2014 11:13:24 AM(UTC)
Water dispenser and ice machine not working (Refrigerator & Freezer Repair)
by josht_tl 11/18/2013 11:15:20 AM(UTC)
