on my Thermador cook top model GGS36w Two burner on right side, top/bottom works. Two burner on left side does not. I replaced igniter, injector sleeve,hoder and piping. When you turn know on, you can here the clicking noice but no gas. I checked the solenoid valve. removed the power. I read zero ohms. Do I need to replaced two solenoid valve part no. AP2828839? do I need to do any other testing?
