Front panel does not work. Smack it or wiggle the front panel it may come on and work for awhile. Next time around do the same thing over again and the front panel may work again. So I assume it is the front panel? Or is it some other problem with a dead front panel?
Very likely there is a loose wire or contact somewhere inside the control panel. You have to open the control panel and inspect all wires and connections. Post the results. Here is the Tech sheet. Gene.
Thank You Gene! Will look. How much does the panel cost? Or part number if defective. Is this a easy repair? Looked around how to remove panel and have no luck so far. I'm new at this. Can you help me?
For the instructions click on the Tech sheet link in the previous reply.
