njrich50
#1 Posted : Wednesday, May 5, 2010 7:51:39 AM(UTC)
njrich50
Front panel does not work. Smack it or wiggle the front panel it may come on and work for awhile. Next time around do the same thing over again and the front panel may work again. So I assume it is the front panel? Or is it some other problem with a dead front panel?
#2 Posted : Wednesday, May 5, 2010 3:13:44 PM(UTC)
Very likely there is a loose wire or contact somewhere inside the control panel. You have to open the control panel and inspect all wires and connections. Post the results.
Here is the Tech sheet.
njrich50
#3 Posted : Wednesday, May 5, 2010 3:18:06 PM(UTC)
njrich50
Thank You Gene! Will look. How much does the panel cost? Or part number if defective. Is this a easy repair? Looked around how to remove panel and have no luck so far. I'm new at this. Can you help me?
#4 Posted : Wednesday, May 5, 2010 7:58:57 PM(UTC)
For the instructions click on the Tech sheet link in the previous reply.
njrich50
#5 Posted : Friday, May 7, 2010 6:14:20 AM(UTC)
njrich50
Thanks Gene!
#6 Posted : Friday, May 7, 2010 2:38:51 PM(UTC)
Kenmore Elite HE4 (Dryer Repair)
by harleyutc 4/21/2013 12:30:44 PM(UTC)
Kenmore Elite HE4 heat stopped working (Dryer Repair)
by aearlv 1/5/2013 3:42:14 PM(UTC)
kenmore elite he4 (Dryer Repair)
by Grandmabal 1/2/2013 4:23:51 PM(UTC)
Kenmore Elite HE4t getting VERY hot (Dryer Repair)
by blkrx8 9/14/2012 11:58:26 AM(UTC)
Kenmore Elite HE4 no power (Dryer Repair)
by dleach 5/19/2012 9:09:05 AM(UTC)
Kenmore elite he4t No power after ccu replaced (Washer Repair)
by junit 10/7/2011 1:11:36 PM(UTC)
Kenmore Elite HE4 Washer - 1) display lights malfunction, 2) long wash times (Washer Repair)
by site172000 11/1/2009 5:29:27 AM(UTC)
Kenmore Elite he4t f11 & fdl error codes (Washer Repair)
by glittleton 9/25/2009 10:42:24 AM(UTC)
kenmore elite HE4t time flashes and wont run cycle (Washer Repair)
by cate rogers 6/25/2009 7:52:34 AM(UTC)
Kenmore Elite He4 Dryer NO POWER? (Dryer Repair)
by BerkelUSA 6/14/2009 8:58:36 AM(UTC)
kenmore elite HE4T (Washer Repair)
by raider24 7/23/2008 7:38:31 PM(UTC)
kenmore elite he4t no power (Washer Repair)
by CAT88 12/6/2007 11:47:36 AM(UTC)
