dp07@hotmail.com
#1 Posted : Tuesday, June 24, 2008 5:03:16 PM(UTC)
dp07@hotmail.com
I have a GE Nautilus dishwasher that is 4 yrs old. The water will not drain out of the tub. The cycle begins with the water filling and then does not drain. I cleaned the hose line going into the garbage disposal and there is no air gap. Any ideas?
#2 Posted : Wednesday, June 25, 2008 1:49:23 PM(UTC)
Here are the parts which you have to check:
The piston & nut assembly (#564 on the break down diagram), the drain hose for a clog and/or twist or bend, the check valve (#560 on the break down diagram) for a clog, the drain solenoid (# 497 on the break down diagram).
To check some of these parts the dishwasher has to be removed from the cabinet.
Here are the break down diagrams for the GE dishwasher Model GSD3400G00CC, similar to yours.
Mjkinne
#3 Posted : Thursday, August 1, 2013 6:15:18 AM(UTC)
Mjkinne
My problem is there doesnt seem to be enough pressure to clean dishes.
GE Nautilus Dishwasher (Dishwasher Repair)
by Curt Brennan 7/30/2015 10:38:58 AM(UTC)
GE nautilus dishwasher (Dishwasher Repair)
by golfingman 4/18/2014 3:37:08 PM(UTC)
GE Nautilus will not drain (Dishwasher Repair)
by hecven101 8/29/2013 6:21:19 AM(UTC)
GE Nautilus Leaking (Dishwasher Repair)
by brazilianldsjaguar 1/2/2013 2:04:09 PM(UTC)
GE Nautilus Fills with water, then won't run. (Dishwasher Repair)
by SBR65 6/3/2012 5:14:40 PM(UTC)
GE Nautilus won't drain - standing water (Dishwasher Repair)
by cherylbland 1/6/2012 6:22:24 AM(UTC)
Ge Nautilus (Dishwasher Repair)
by AnnMatilda 10/21/2011 1:46:49 PM(UTC)
GE nautilus dishwasher doesn't push water to top arm and won't drain (Dishwasher Repair)
by ole joe 7/19/2011 5:50:24 PM(UTC)
GE NAUTILUS Not pumping out completely (Dishwasher Repair)
by HoundDoggy 3/17/2011 1:45:33 PM(UTC)
GE Nautilus won't start (Dishwasher Repair)
by Olivematt 3/1/2011 5:46:04 AM(UTC)
GE Nautilus (Dishwasher Repair)
by dre2142 1/31/2011 3:44:10 PM(UTC)
GE Nautilus odd model number (Dishwasher Repair)
by macdouga 1/22/2011 3:33:03 PM(UTC)
GE Nautilus Dishwasher making noise (Dishwasher Repair)
by Krowell 12/10/2010 6:27:22 AM(UTC)
by Jess9375 11/30/2010 3:32:34 PM(UTC)
by thomasc 9/10/2010 12:27:26 PM(UTC)
