when i try to start the oven it try to ignite all burner it click 3 time and it stop ignite i try to check the code on control panel it says e0f3 means ' oven sansor opened some time it says e1 f3 means oven sansor shorted i changed the sansor but it does the same thing please some one help me thank you! (stovetop work perfect)
Rank: Administration
Check the harness between the sensor and the control board. Make sure the wiring is ok and make sure that the harness is properly plugged in the board.
