bob zaveri
#1 Posted : Thursday, August 30, 2007 2:29:06 PM(UTC)
bob zaveri
when i try to start the oven it try to ignite all burner it click 3 time and it stop ignite i try to check the code on control panel it says e0f3 means ' oven sansor opened some time it says e1 f3 means oven sansor shorted i changed the sansor but it does the same thing please some one help me thank you! (stovetop work perfect)
Admin / APP Team
#2 Posted : Thursday, August 30, 2007 6:43:51 PM(UTC)
Admin / APP Team
Rank: Administration
Check the harness between the sensor and the control board. Make sure the wiring is ok and make sure that the harness is properly plugged in the board.
Whirlpool oven does not work but burners on top do. (Oven Repair (including Ranges and Cooktops))
by formula2fast 12/25/2012 7:13:16 AM(UTC)
whirlpool oven does not work (Oven Repair (including Ranges and Cooktops))
by Alketa 6/9/2011 8:23:05 AM(UTC)
