How do I remove the worm gear int the gearcase to replace the Input Shaft Oil Seal Kit?
What the model number?
Sears sent two replacement seals, one is black (seen from the outside) and a red one with a smaller inside diameter that I think must me behind the black seal?
Would you have a suggestion on the best way to remove the old seal(s)?
