csking408
#1 Posted : Thursday, April 29, 2010 10:35:05 AM(UTC)
csking408
My dishwasher leaves about 2-3 gallons of water in the bottom at the end of a completed cycle. I have already checked the air gap (put a 3 ft cable tie down to confirm there was no blockage). I also drained all the water and took the hose off (check valve) under the dishwasher to confirm no blockage. I can't figure out how to easily get to the drain in the dishwasher to confirm no blockage there. Are there any other diy tips before I call a repairman? I have 4 kids and loosing my dishwasher is killing my already not-so-smooth hands :)
#2 Posted : Friday, April 30, 2010 1:01:15 AM(UTC)
Replacement parts for WHIRLPOOL GU1200XTLS3 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
And a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Am not sure how you checked the air gap.
You have to check it from the machine to the air gap and from the air gap to the house plumbing.
Check to see if the drain pump is running.
If it sounds/feels like it is then I would undo the drain hose at the air gap and try to drain it into a pail. Be sure to hold the hose securely in the pail and put a towel etc. over it so it does not splash all over. If it now drains your problem is either the air gap or a blockage (air gap to house drain.
If drain pump does not seem to run then check to see if it is getting power when it should.
If it is and tthe pump is not running it is probably toast or has something jamming it.
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
