patrick tierney
#1 Posted : Wednesday, April 28, 2010 6:48:38 AM(UTC)
patrick tierney
Has power, set all the temps and time and all that good stuff, press start button and you can hear a beep but nothing happens. what do i need to check or replace. HELP PLEASE.
#2 Posted : Wednesday, April 28, 2010 7:38:51 AM(UTC)
Replacement parts for WHIRLPOOL WED8300SW1 27" Electric Dryer | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572759.pdf
Try the diagnostics on Page 2 of the tech sheet.
If the motor circuit fails.
You will see from the wiring diagram in the tech sheet you have 2 shut off devices in line with your motor. That is where I would start.
Could be that the belt is broken.
Could be that the thermal fuse is blown.
This is the one on the blower (Item 38 in Section 3)
The most common cause of this blowing is a dirty vent system or it's louvers not opening.
Motor running -- nothing happening (Dishwasher Repair)
by sueono 12/16/2010 9:13:42 AM(UTC)
