Freezer fan runs all the time. Is this normal? Freezes and cools well. No frost build up. Less than a year old and under warranty. Again, is this normal? Thanks Grumps
On most units the evaporator (freezer) fan does run almost all the time. it is required to circulate cold air in both the freezer and fresh food sections.
It does shut off during defrost but you unit may only be doing this every couple days for 20 to 30 minutes. |
THIS FORUM IS DEAD!!!!!!! |
