Icemaker will not produce ice. I removed it unplugged it and cleaned it. It had ice still in place, but would not eject it. Optics work fine, two flashes when blocked and steady red when not. Water to door dispenser good and strong. Will placing it back into freezer and reconnecting it cause it to cycle and indicate if it is fuctioning or could there still be a problem with the water valve? At this time I have reconnected it and it looks like the fingers have moved from pointing to the front to about the 4:00 position. Thanks, John
I am a user, not a pro. My ice was stuck. I heated the metal tray bottom with a hair dryer until the ice melted some and released and magically the fingers started moving and pushed the ice out. It was my fault because I poured extra water into the tray (no water flow) and obviously got too much water in for the heater to work properly. My problem now is that the water will not flow into the tray.
Hope this helps.
