The unit leaks water from the bottom center. I suspect it might be related to the sump inlet or connector pump assembly. I went ahead to buy the parts. Do I need to apply sealant for the sump inlet and connector pump assebly prior to assemble the parts.
thanks.
Rank:: Advanced Member
