MasterDIY
#1 Posted : Thursday, June 19, 2008 4:41:28 AM(UTC)
MasterDIY
The unit leaks water from the bottom center. I suspect it might be related to the sump inlet or connector pump assembly. I went ahead to buy the parts. Do I need to apply sealant for the sump inlet and connector pump assebly prior to assemble the parts.
thanks.
abadfish66
#2 Posted : Thursday, June 19, 2008 7:13:20 AM(UTC)
abadfish66
No sealant is required
