:confused: will not not turn on. tried turning off , could it be the control board ?
:confused: will not not turn on. tried turning off , could it be the control board ? maytag mdb6601awq
Can you be more clear as to what the problem is. Is there anything at all going on with the dishwasher, lights, noise, etc... Do you have power at the outlet your dishwasher is plugged into, or if it's hard wired, is the breaker in the on position
Originally Posted by: abadfish66 Can you be more clear as to what the problem is. Is there anything at all going on with the dishwasher, lights, noise, etc... Do you have power at the outlet your dishwasher is plugged into, or if it's hard wired, is the breaker in the on position no lights, i reset the breaker it is only 2 years old could it be the control board ?
It could be everything. We can help you with our advises but only if you are ready to follow them and can answer on our questions.
In such situation the first thing is to verify the proper power to the dishwasher.
