AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
How do I replace the water line in freezer door of GE side by side?
There is a break in the water line leading up from the base of the fridge to the dispenser and I need to replace the line. How do I remove the old water line?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: Gene  Hey Gene.. what about the GSH25KGRBWW model... is the line removable and replacable???
Mark
Usually the break is at the bottom or top. Most of the time the line at the fountain end can be pulled up a bit, and the line cut to remove a bad section. If at the bottom little harder. Usually you can just clip away the bad section and use couplers to spice in a new section.
