bthoma121
#1 Posted : Thursday, April 22, 2010 1:33:33 PM(UTC)
bthoma121
There is a break in the water line leading up from the base of the fridge to the dispenser and I need to replace the line. How do I remove the old water line?
#2 Posted : Thursday, April 22, 2010 4:27:10 PM(UTC)
Looks like the only way to do it is to remove the inner door panel. I'm not sure if it's removable on this model. You have to determine it yourself.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25SGPESS Refrigerator | AppliancePartsPros.com
mark63
#3 Posted : Wednesday, August 10, 2011 8:30:57 PM(UTC)
mark63
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
mark63
#4 Posted : Wednesday, August 10, 2011 8:32:01 PM(UTC)
mark63
Hey Gene.. what about the
GSH25KGRBWW model... is the line removable and replacable???
Mark
#5 Posted : Thursday, August 11, 2011 1:40:38 AM(UTC)
Usually the break is at the bottom or top. Most of the time the line at the fountain end can be pulled up a bit, and the line cut to remove a bad section.
If at the bottom little harder. Usually you can just clip away the bad section and use couplers to spice in a new section.
