Problem: The igniter will keep sparking after the burner has been flamed.
Hi Michael, Check the igniter for any damage to the ceramic part and/or grease on or around. If the igniter is damaged, the replacement part unfortunately is no longer available. If there is nothing wrong then the spark module has to be replaced. - The part number for the spark module is AP2821617 Here are the break down diagrams for the Thermador stove Model SGT36G01Gene.
