Michael123
#1 Posted : Sunday, June 15, 2008 9:22:25 PM(UTC)
Michael123
Problem: The igniter will keep sparking after the burner has been flamed.
#2 Posted : Monday, June 16, 2008 7:17:40 PM(UTC)
Hi Michael,
Check the igniter for any damage to the ceramic part and/or grease on or around. If the igniter is damaged, the replacement part unfortunately is no longer available.
If there is nothing wrong then the spark module has to be replaced.
- The part number for the spark module is AP2821617
Here are the break down diagrams for the Thermador stove Model SGT36G01
