kenro
#1 Posted : Sunday, June 15, 2008 6:48:14 PM(UTC)
kenro
We have a Tappan oven beeping and showing F5 Code after a power outage. The only time is does not do this is when the oven is on. Do we need to replace the EOC? Is this the same as the oven timer control? Is this a hard repair to do? Part is pricey, but not as much as new stove. Thanks!
stonespike
#2 Posted : Saturday, June 28, 2008 9:06:53 AM(UTC)
stonespike
I have the exact same F5 problem, but mine didn't show up until a week or so after a power outage and I used the broiler. I shut off the broiler and then it started with the F5 and annoying beeping. Can you lead me to a fix on this issue?
f5 error code on fridgidaire (Oven Repair (including Ranges and Cooktops))
Belarus jmarker 7/29/2014 4:10:42 PM(UTC)
F5 error code and beeping on bake, clean, and broil (Oven Repair (including Ranges and Cooktops))
by ghmoore 12/23/2011 7:02:15 AM(UTC)
Ge Oven JTP15 F2 F3 F5 error codes (Oven Repair (including Ranges and Cooktops))
by rountad 8/31/2010 11:06:07 AM(UTC)
Oven slow to preheat, with f5 error code (Oven Repair (including Ranges and Cooktops))
by gkademo 12/13/2009 7:23:45 AM(UTC)
Jenn Air F5 error code - "Clock" or Power relay board? (Oven Repair (including Ranges and Cooktops))
by chanpaul 11/22/2009 1:13:48 PM(UTC)
by 2thdr 7/4/2009 1:50:52 AM(UTC)
Jenn-Air F5 error code. (Oven Repair (including Ranges and Cooktops))
by rlb1950 11/7/2008 11:32:45 AM(UTC)
