jmarker
#1 Posted : Tuesday, July 29, 2014 4:10:42 PM(UTC)
jmarker
Hi there I got a fridgidaire flat top oven flashing f5 I can't find EOC PART eoc is located where I cannot find the part anywhere in the stove does it have another name?
#2 Posted : Wednesday, July 30, 2014 1:20:58 AM(UTC)
Parts for Frigidaire GLEF396ASA Range - AppliancePartsPros.com
The EOC is item F20 in section 03.
If this needs replacing you may also need a new overlay (item 20A in section 03).
Have you tried unplugging the range for a few minutes to see if it will reset?
jmarker
#3 Posted : Wednesday, July 30, 2014 11:08:01 AM(UTC)
jmarker
Yes sir and nothing happens
#4 Posted : Thursday, July 31, 2014 1:27:56 AM(UTC)
This is one complex unit.
Below is a service manual.
You will have to join the site and be logged in to be able to download the manual.
Page 22 shows an F5 error.
http://appliancejunk.com...wnloads;sa=view;down=283
There are other manuals in the Range, Oven & Cooktop Service Manuals section for Frigidaires that may have additional info.
Looks like it is a communications error so the following may help.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
