marker2001
#1 Posted : Wednesday, April 14, 2010 6:42:49 AM(UTC)
marker2001
You have been a member since:: 4/14/2010(UTC)
Everything "seems" fine - lights and features all work.
Here are the symptoms:
  • When the system is turned on, it makes a louder humming noise than normal and then it stops heating after about 2 - 3 minutes. The system still continues to run, just no hum and no heating.
  • When making popcorn, I noticed that the steam produced stays in the chamber and does not get expelled.
Any suggestions?
TIA,
Mark
magician59
#2 Posted : Wednesday, April 14, 2010 7:13:44 AM(UTC)
magician59
sounds like a bad capacitor/diode.
marker2001
#3 Posted : Wednesday, April 14, 2010 7:18:52 AM(UTC)
marker2001
Would that also explain the lack of venting inside the chamber? Or, do I have a fan problem too? :confused:
magician59
#4 Posted : Wednesday, April 14, 2010 9:13:48 AM(UTC)
magician59
The steam inside the oven may point to a bad fan. This may be what caused the microwave to malfunction.
