cwp03
#1 Posted : Tuesday, April 13, 2010 3:33:40 AM(UTC)
cwp03
The refrigerator stopped cooling properly and I noticerd the evaporater fan was not running. I replaced the fan motor. It is running but the refrigerator is still only 58 degrees F. The freezer is fine.Is there something I forgot to check and replace?
magician59
#2 Posted : Tuesday, April 13, 2010 7:25:20 AM(UTC)
magician59
Look for a very light frost covering the entire evaporator coil while the compressor is running. If you don't see this, you either have a refrigerant leak or some kind of system restriction. Also, check to make sure the damper is open.
cwp03
#3 Posted : Tuesday, April 13, 2010 8:50:10 AM(UTC)
cwp03
There is a light frost, but the openings from freezer to the fridge is completely iced up blocking any air movement. Could this be a thermostat,heater, or power board? The freezer seems to work fine.
magician59
#4 Posted : Tuesday, April 13, 2010 9:24:41 AM(UTC)
magician59
This indicates a defrost problem. Most likely to be a burnt out defrost heater.
cwp03
#5 Posted : Tuesday, April 13, 2010 10:11:39 AM(UTC)
cwp03
If the heater checks out, would you suspect the thermostat or the power board?
magician59
#6 Posted : Tuesday, April 13, 2010 11:35:54 AM(UTC)
magician59
If the heater is OK, I would suspect the board. The thermostat isn't responsible for initiating the defrost cycle; it only cuts power to the heater. Good idea, though, if the heater is bad, to also replace the thermostat.
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
GE Cafe Refrigerator not cooling properly/ice build up inside by vents (Refrigerator & Freezer Repair)
by september22 6/1/2015 11:16:31 AM(UTC)
Refrigerator not cooling properly.... (Refrigerator & Freezer Repair)
by rwwells05 12/5/2011 5:23:57 PM(UTC)
GE Refrigerator Not Cooling Properly (Refrigerator & Freezer Repair)
by Mazhar1 3/4/2011 7:14:21 AM(UTC)
Refrigerator not cooling properly (Refrigerator & Freezer Repair)
by kjr56 5/27/2008 8:19:12 AM(UTC)
