homesbygreg@aol.com
#1 Posted : Monday, April 12, 2010 11:16:29 AM(UTC)
homesbygreg@aol.com
I am trying to find the diagram and set by step instructions to disassemble the heater assembly and thermal light. Can you help me please? My dryer is not heating. I checked the 3 thermostats with an ohm meter. If you have the instructions to ohm each device that would be great too. Thank you in advance.
#2 Posted : Monday, April 12, 2010 4:04:42 PM(UTC)
You may want to start the troubleshooting with confirming of 240 VAC to the dryer. Your dryer is electric and it needs 240 VAC for the heating element while the motor needs only 120 VAC.
Here is the wiring diagram.
homesbygreg@aol.com
#3 Posted : Thursday, April 15, 2010 8:39:45 AM(UTC)
homesbygreg@aol.com
The plug has 240 going to it. What should I do next?
#4 Posted : Friday, April 16, 2010 7:59:04 PM(UTC)
The next step is to check for continuity the high limit thermostat, thermal limiter and heater (#33, #36 & #15 on the diagram).
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
The disassembly instructions are attached to the reply.
- The high limit thermostat Part number: AP2131477
- The thermal limiter Part number: AP2108182
- The heater assembly Part number: AP4501537
File Attachment(s):
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
by creative582 1/6/2013 2:52:04 PM(UTC)
Dryer will not heat. Ignitor willnot glow (Dryer Repair)
by margonz 12/9/2010 6:29:47 PM(UTC)
Kenmore dryer will not heat.3 weeks-- my wife is mad (Dryer Repair)
by topagent 7/31/2009 12:51:43 PM(UTC)
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 11/22/2007 5:52:59 AM(UTC)
