My amana electric dryer won't heat up. I have tested the fuse, cutoff and element for continuity and all test good. Everything else works fine.
Here are your parts Replacement parts for AMANA LEA60AW Dryer - Ele | AppliancePartsPros.comAnd a manual http://www.servicematters.com/maytag_library/docs/RS3200005R2.pdf[COLOR="Blue"]I have tested the fuse, cutoff and element for continuity and all test good.[/COLOR] You also have the main control thermostat (cycling) First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts. If this does nothing. Measure the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off If OK Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal. |
THIS FORUM IS DEAD!!!!!!! |
