timjmix11
#1 Posted : Sunday, April 11, 2010 5:57:28 PM(UTC)
timjmix11
My amana electric dryer won't heat up. I have tested the fuse, cutoff and element for continuity and all test good. Everything else works fine.
#2 Posted : Monday, April 12, 2010 5:47:59 AM(UTC)
Replacement parts for AMANA LEA60AW Dryer - Ele | AppliancePartsPros.com
And a manual
http://www.servicematters.com/maytag_library/docs/RS3200005R2.pdf
[COLOR="Blue"]I have tested the fuse, cutoff and element for continuity and all test good.[/COLOR]
You also have the main control thermostat (cycling)
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
Amana Dryer won't heat (Dryer Repair)
by bangacan 11/28/2013 10:57:32 AM(UTC)
