Chil
#1 Posted : Friday, April 9, 2010 11:56:59 AM(UTC)
Chil
I have Maytag washer series 17. I ordered and recieved pump AP4373022 to fix problem with the washer not spinning all the water out during spin cycle.My question is, the old pump with assembly has a black circular plate.Which the replacement part did not come with.Do I need to transfer the circlar plate from the old pump to the new before installing? If so how? due to sealed pump housing I don't see were to access the screw in order to remove the plate.HELP ME Please!
sidfink43
#2 Posted : Friday, April 9, 2010 12:20:23 PM(UTC)
sidfink43
Maytag changed the design of that pump, presumably for good reason although you never know. They should have included a notice with the part, but they did not.
You do not need to remove the plate on the old one, just install the new one as is.
Here is a Maytag tech bulletin on the issue.
http://www.servicematters.com/m...ary/docs/ITDL-0031-B.pdf
