w491cz
#1 Posted : Tuesday, June 10, 2008 8:57:37 AM(UTC)
w491cz
The defrost drain appears to be clogged. How do I find the defrost drain on this particular refrigerator so I can un-clog it?Thanks
abadfish66
#2 Posted : Tuesday, June 10, 2008 10:09:40 PM(UTC)
abadfish66
It is on the freezer side, below the evaperator coils. You may or may not need to remove the back panel of the freezer to find the drain hole. Also if you remove the rear access panel at the rear of the machine, you will see a plastic tube, this is your drain tube
GE Clogged defrost drain (Refrigerator & Freezer Repair)
by eng3 12/30/2019 5:27:03 PM(UTC)
Can't Access Clogged Defrost Drain (Refrigerator & Freezer Repair)
by kevin007 8/21/2012 9:59:01 AM(UTC)
Refrigerator - Water on Floor, Repairing a Clogged Defrost Drain (Refrigerator & Freezer Repair)
by mousavi2011 3/25/2011 10:25:25 AM(UTC)
Clogged Defrost drain (Refrigerator & Freezer Repair)
by Stef 5/11/2010 12:22:38 PM(UTC)
Probable Clogged Defrost drain tube (Refrigerator & Freezer Repair)
by Stef 7/22/2008 6:35:21 AM(UTC)
