nc4362
#1 Posted : Tuesday, June 10, 2008 6:27:55 AM(UTC)
nc4362
The circuit breaker trips everytime the microwave model #GE JVM1650CH01 is turned on to cook. All other features works, i.e. lights, vents, clock.
abadfish66
#2 Posted: : Tuesday, June 10, 2008 7:40:13 AM(UTC)
abadfish66
Is there a loud buzzing noise when you hit start and before the breaker trips? Your either going to be looking at a weak house breaker, or a shorted transformer in your microwave. Run an extension cord from the microwave to a different outlet and see if it trips that breaker, if it does your transformer is bad. Only run the micro on the extension cord for a short time, 10-15 seconds, as the added resistance in the extension cord will trip the breaker as well.
nc4362
#3 Posted : Tuesday, June 10, 2008 7:50:46 AM(UTC)
nc4362
I already tried running the Microwave using the extension cord to a different outlet, it also trips the breaker on that outlet. I did not notice a loud buzzing noise before the breaker trips.
abadfish66
#4 Posted : Tuesday, June 10, 2008 8:24:32 AM(UTC)
abadfish66
Sounds like your high voltage transformer has a short to ground
