nc4362
#1 Posted : 17 years ago
nc4362
The circuit breaker trips everytime the microwave model #GE JVM1650CH01 is turned on to cook. All other features works, i.e. lights, vents, clock.
abadfish66
#2 Posted : 17 years ago
abadfish66
Is there a loud buzzing noise when you hit start and before the breaker trips? Your either going to be looking at a weak house breaker, or a shorted transformer in your microwave. Run an extension cord from the microwave to a different outlet and see if it trips that breaker, if it does your transformer is bad. Only run the micro on the extension cord for a short time, 10-15 seconds, as the added resistance in the extension cord will trip the breaker as well.
nc4362
#3 Posted : 17 years ago
nc4362
I already tried running the Microwave using the extension cord to a different outlet, it also trips the breaker on that outlet. I did not notice a loud buzzing noise before the breaker trips.
abadfish66
#4 Posted : 17 years ago
abadfish66
Sounds like your high voltage transformer has a short to ground
