ff36ike
#1 Posted : Wednesday, April 7, 2010 11:44:37 AM(UTC)
ff36ike
Given a amana fridge told it as broke I plug it in and nothing happens any suggestions.....has set up for a year buddy said the old owner thought it was the thermostat but didn't know. thanks IKE
#2 Posted : Wednesday, April 7, 2010 4:22:22 PM(UTC)
Locate the defrost timer on the back of the refrigerator (#1541 on the diagram) and slowly turn the shaft (red) CW until it clicks. If the refrigerator will start, replace the defrost timer.
- The defrost timer Part number: AP4246797
ff36ike
#3 Posted : Wednesday, April 7, 2010 5:53:48 PM(UTC)
ff36ike
thanks it seems this is missing will get one and see if it works..
#4 Posted : Wednesday, April 7, 2010 6:00:14 PM(UTC)
ff36ike
#5 Posted : Sunday, April 11, 2010 10:18:01 AM(UTC)
ff36ike
that was it works great thanks!!!!
#6 Posted : Tuesday, April 13, 2010 12:00:44 PM(UTC)
I'm glad you were able to fix it. Thank you for the feed back.
ff36ike
#7 Posted : Sunday, April 18, 2010 10:26:33 AM(UTC)
ff36ike
what would cause it not to cool ? coils are clean do ya think it needs a charge of freon???
#8 Posted : Monday, April 19, 2010 6:51:40 PM(UTC)
Sounds like there is a new problem now?
Make sure the condenser coils are clean and the fan next to it works properly. If there is nothing wrong, then there is a problem with the sealed system. It can be low on Freon or the compressor has gone bad. It has to be tested by a pro.
ff36ike
#9 Posted : Tuesday, April 20, 2010 3:17:11 AM(UTC)
ff36ike
thanks I will have it checked out.
